Provides a high speed, crystal clear connection between your DVI digital devices. The DVIDSMM10 10ft DVI-D Single-Link Cable provides a highly reliable, purely digital connection between and is perfect for hooking up a desktop workstation to a DVI monitor, or to plug a laptop into a projector for presentations.
The single-link cable works with DVI digital flat panel LCD monitors and provides video data transmissions of up to 4.95 Gbps.
This durable monitor cable is designed to provide a high quality digital video experience.
Product Description | StarTech.com 10 ft DVI-D Single Link Cable - M/M - DVI cable - 3 m | Type | DVI cable - single link | Length | 3 m | Connector | DVI-D - male | Connector (Second End) | DVI-D - male | Compliant Standards | Plug and Play | Colour | Black | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: SP123DP2DVI, IP2DVI, PEX2PCI4GB, PEX2PCI4, ST122DVIGB, ST124DVI, ST122DVI |
General | |
Type | DVI cable |
American Wire Gauge (AWG) | 28 |
TMDS Links | Single link |
Length | 3 m |
Colour | Black |
Connectivity | |
Connector | 18+1 pin digital DVI (Single-Link) - male |
Connector (Second End) | 18+1 pin digital DVI (Single-Link) - male |
Miscellaneous | |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
Designed For | StarTech.com 2 Port DVI-I Video Splitter - Digital and Analog, 4 Port DVI-I Video Splitter - Digital and Analog, Ethernet to DVI Video Adapter over IP, PCI Express to 4 Slot PCI Expansion System, TripleHead DisplayPort to DVI Multi Monitor Adapter |
