StarTech.com 10 ft DVI-D Single Link Monitor Extension Cable...
StarTech.com 10 ft DVI-D Single Link Monitor Extension Cable - M/F
£14.91
Select:
Delivery:
Standard: 1-3 working days
Product codes
This 10ft single-link DVI-D extension cable offers a high quality connection that allows you to get the most out of your high-end digital video card and flat-panel digital LCD monitor.
With DVI-D technology, no digital-to-analog conversion is necessary, so the signal is delivered faster and stronger than a standard monitor cable signal. The plug and play-compatible, all-digital connection provided by this DVI-D extension cable is also ideal for connecting laptop computers to digital projectors for crystal-clear presentations.
By interfacing two digital signals directly, you'll experience faster, higher-quality images. This single-link cable works with virtually any DVI digital flat panel LCD monitor and allows high-speed DVI video data transmissions of up to 4.95 Gbps.
Product Description StarTech.com 10 ft DVI-D Single Link Monitor Extension Cable - M/F - DVI extension cable - 3 m
Type DVI extension cable - single link
Length 3 m
Connector DVI-D - male
Connector (Second End) DVI-D - female
Compliant Standards Plug and Play
Colour Black
Designed For P/N: ST122DVIGB, ST124DVI, ST122DVI
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10 ft DVI...
£14.91
