StarTech.com 10 ft DVI-I Dual Link Digital Analog Monitor Ext...
StarTech.com 10 ft DVI-I Dual Link Digital Analog Monitor Extension Cable M/F
£16.42
11 in stock
Delivery:
Standard: 1-3 working days
  • Type: DVI
  • Length: 3.05m
  • Stock Status: In Stock
Product codes
Extend your DVI-I (dual link) connection by 10ft. The DVIIDMF10 DVI-I Dual-Link Digital Analog Monitor Extension Cable allows you to extend the connection distance between your DVI-I devices by up to 10-feet.
The dual link cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec, and is fully compliant with DVI DDWG standards.
Product Description StarTech.com DVI-I Extension Cable - 10 ft - Dual Link - Digital and Analog - Male to Female Cable - Computer Monitor Cable - DVI Cord (DVIIDMF10) - DVI extension cable - 3.05 m
Type DVI extension cable - dual link
Length 3.05 m
Connector DVI-I - male
Connector (Second End) DVI-I - female
Compliant Standards FCC
Colour Black
Designed For P/N: AGPVID5500A, ST121UTPDVGB
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10 ft DVI...
£16.42
