StarTech.com 10 ft Flat High Speed HDMI Cable with Ethernet -...
StarTech.com 10 ft Flat High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable
£11.38
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Length: 3m
  • Stock Status: In Stock
Product codes
Create Ultra HD connections between your HDMI-enabled devices with minimal clutter; supports Ethernet Data Channel. The HDMIMM10FL Flat High Speed HDMI Cable (10-foot) supports the advanced capabilities of the High Definition Multimedia Interface, including Ethernet data interconnectivity with compatible HDMI devices. The cable features a flat-shaft design that makes it the ideal solution for in-wall installations or installation under carpet or along baseboards.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
Product Description StarTech.com Flat High Speed HDMI Cable w/ Ethernet - Ultra HD 4k x 2k - HDMI with Ethernet cable - 3 m
Cable HDMI with Ethernet cable
American Wire Gauge (AWG) 24
Length 3 m
Colour Black
Connector HDMI - male
Connector (Second End) HDMI - male
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10 ft Fla...
£11.38
