StarTech.com 10 ft HDMI to DVI-D Cable - M/M
£10.58
Select:
Delivery:
Standard: 1-3 working days
Key features
  • Ensures compatibility between two distinct digital video interfaces
  • Eliminates the need for multiple cables and clutter
  • Guaranteed reliability
  • Type: HDMI
  • Length: 3m
  • Stock Status: In Stock
Product codes
Connect an HDMI-enabled output device to a DVI-D display, or a DVI-D output device to an HDMI-capable display. The HDMIDVIMM10 10-foot HDMI to DVI-D cable enables you to connect a DVI-D video card (or other DVI-D output device) to a display that incorporates HDMI technology; the cable supports bi-directional operation that also allows the reverse configuration, delivering digital video from an HDMI-enabled output to a DVI-D capable display.
A valuable addition to any digital signage, multimedia or home theater application, this high performance cable is designed to provide the best quality picture available through either HDMI technology or DVI digital connections.
Product Description StarTech.com 10ft HDMI to DVI D Adapter Cable - Bi-Directional - HDMI to DVI / DVI to HDMI Adapter for Your Computer Monitor (HDMIDVIMM10) - video cable - 3 m
Cable Video cable
Length 3 m
Colour Black
Connector HDMI - male
Connector (Second End) DVI-D - male
Designed For P/N: BOX4CABLE, DKT30CDVPD, HDBOOST, HDVGADP2HD, RKCOND17HD, ST121HD20FXA, ST121HDBTSC, ST121USBHD, ST121WHDS, ST12MHDLAN4K, ST12MHDLAN4R, ST12MHDLANU, ST12MHDLANUR, ST12MHDLNHK, ST12MHDLNHR, STDHVHDBT, TB32HD2, USB32DVCAPRO, USB32HD2, USBC2DVCAPRO, UVCHDCAP, VID2HDCON2, VS421HD4KA, VS424HD4K60
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10 ft HDM...
£10.58
