StarTech.com 10 ft Mini DisplayPort to DisplayPort 1.2 Adapte...
StarTech.com 10 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k
£11.34
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Latching DisplayPort connector prevents accidental disconnection
  • Cost-effective solution for adding a standard DisplayPort connection to your Mini Displayport-equipped PC or Mac
  • Guaranteed reliability
  • Stock Status: In Stock
Product codes
Create a high-resolution 4k x 2k connection with HBR2 support between your Mini DisplayPort-equipped laptop and a standard DP monitor. The MDP2DPMM10 10ft Mini DisplayPort to DisplayPort Adapter Cable, features a Mini DP male connector on one end, and a DP male connector on the other, allowing you to connect any Mini DisplayPort-equipped laptop (including the Mac family of products) to an HDTV, monitor or projector that uses a standard DisplayPort connection.
The mDP to DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
Newer laptop and desktop computers (e.g. Apple) come equipped with Thunderbolt ports only. The Mini DP to DP Cables can be connected to the Thunderbolt ports, enabling you to connect your DP compatible displays.
Product Description StarTech.com 10ft Mini DisplayPort to DisplayPort Cable - M/M - mDP to DP 1.2 Adapter Cable - Thunderbolt to DP w/ HBR2 Support (MDP2DPMM10) - DisplayPort cable - 3 m
Type DisplayPort cable
Length 3 m
Connector Mini DisplayPort - male
Connector (Second End) DisplayPort - male
Compliant Standards RoHS
Designed For P/N: BOX4HDECP, CDP2MDP, CDP2MDPFC, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDMDP, DPBOOST, HD2DP, MDPEXT3, SP123DP, SV431DPDDUA2, SV431DPUA2
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10 ft Min...
£11.34
