StarTech.com 10 ft Mini DisplayPort to DVI Adapter Converter...
StarTech.com 10 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 Black
£23.44
Delivery:
Standard: 1-3 working days
Key features
  • Connect a Mini DisplayPort source directly to a DVI monitor or projector, with a single male-male cable
  • Stock Status: In Stock
Product codes
Connect a DVI display to a Mini DisplayPort-equipped PC or MAC over a longer 10 foot distance - Black. The MDP2DVIMM10B Mini DisplayPort to DVI Adapter Cable lets you directly connect your Mini DP video source (desktop PC, laptop, Ultrabook, etc.) to a DVI monitor or projector, eliminating the expense of having to upgrade to a Mini DisplayPort-capable monitor.
The adapter cable is 10 feet (3 m) in length, and features male-to-male connectors, allowing you to connect your Mini DisplayPort source directly to a DVI display with no additional cabling required.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over ThunderboltI/O port, the adapter supports resolutions up to 1920x1200 (WUXGA).
MDP2DVIMM10Bis a passive adapter that requires a dual-mode DisplayPortport (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
Product Description StarTech.com 10ft Mini DisplayPort to DVI Adapter Cable - Mini DP to DVI Video Converter - MDP to DVI Cable for Mac / PC 1920x1200 - Black (MDP2DVIMM10B) - DisplayPort cable - 3.04 m
Type DisplayPort cable
Length 3.04 m
Connector Mini DisplayPort - male
Connector (Second End) DVI-D - male
Compliant Standards FCC, RoHS
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10 ft Min...
£23.44
