StarTech.com 10 ft Mini DisplayPort to VGA Adapter Converter...
StarTech.com 10 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - White
£25.42
Delivery:
Standard: 1-3 working days
Key features
  • Connect a Mini DisplayPort source directly to a VGA display or projector, with no additonal adapters or cables
  • Save upgrade costs by connecting your Mini DisplayPort computer to a VGA monitor or Projector
  • Well-suited for Mac computers, with uniform white design
  • Flexible monitor placement, with 10ft of cable length
  • Length: 3.05m
  • Stock Status: In Stock
Product codes
Connect a Mini DisplayPort-equipped PC or Mac to a VGA monitor/projector, with a 10ft long white cable. The MDP2VGAMM10W 10ft active Mini DisplayPort to VGA converter cable lets you connect your Mini DisplayPort-equipped device (Desktop PC, Mac, Laptop, Ultrabook, etc.) directly to a VGA monitor or projector with no additional adapters or cables required - a cost-effective solution for enabling your Mini DisplayPort computer to work with a VGA monitor or projector. The cable features a stylish white design, that is well-suited for connecting Mac computers.
The adapter cable is compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port. Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
Product Description StarTech.com 10ft Mini DisplayPort to VGA Adapter Cable mDP to VGA - White - video converter - black
Device Type Video converter
Max Resolution 1920 x 1200
Interfaces 1 x DisplayPort output - Mini DisplayPort , 1 x VGA input - 15 pin HD D-Sub (HD-15)
Enclosure Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10 ft Min...
£25.42
