StarTech.com 10 ft Straight Through Serial Cable - M/F
£5.40
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Length: 3m
  • Stock Status: In Stock
Product codes
This 9-pin Straight Through Serial Cable features a DB9 male connector and a DB9 female connector, allowing you to extend a serial device connection by up to 10ft. The serial cable is constructed using high quality components and design.
Product Description StarTech.com 10 ft Straight Through Serial Cable - M/F - Serial extension cable - DB-9 (M) to DB-9 (F) - 10 ft - gray - MXT10010 - serial extension cable - 3 m
Type Serial extension cable
Length 3 m
Connector 9 pin D-Sub (DB-9) - male
Connector (Second End) 9 pin D-Sub (DB-9) - female
Colour Grey
Designed For P/N: IC232TTL, ICUSB23208FD, ICUSB23216FD, ICUSB2321F, ICUSB2324, ICUSB2324I, ICUSB232D, ICUSB232DB25, ICUSB232PRO, ICUSB232V2, PCI2S232485I, PCI2S4851050, PCI4S954PW, PEX1S1P952, PEX4S232485, ST121UTP232
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10 ft Str...
£5.40
