StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M
£4.59
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Length: 3m
  • Stock Status: In Stock
Product codes
Connect USB 2.0 peripherals to your computer. The USB2HAB10 10ft USB A-to-B cable features one USB 'A' male connector and one USB 'B' male connector, providing a high quality connection to USB 2.0 peripherals such as USB printers, scanners or external USB hard drives.
Product Description StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M - 10ft type a to b USB Cable - 10ft a to b USB 2.0 Cable (USB2HAB10) - USB cable - USB to USB Type B - 3 m
Type USB cable
Features Molded
Length 3 m
Connector 4 pin USB Type A - male
Connector (Second End) 4 pin USB Type B - male
Compliant Standards USB / USB 2.0
Colour Black
Designed For P/N: ICUSB23208FD, ICUSB23216FD, ICUSB232D, IPUSB2HD3, IPUSB2VGA2, PM1115UW, PM1115UWEU, RKCOND17HD, ST12MHDLANU, ST12MHDLANUR, ST4200MINI2, SV231DPDDUA2, SV231USBDDM, SV431DL2DU3A, SV431DPDDUA2, SV431DPUA2, SV431DVIUAQV, SV431DVIUDDM, USB2001EXT2NA, USB2002EXT2NA, USB2004EXT2NA, USB3EXT6INBK
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10 ft USB...
£4.59
