StarTech.com 10 ft VGA Monitor Cable - HD15 MM
£5.37
Select:
17 in stock
Delivery:
Standard: 1-3 working days
  • Length: 3m
  • Stock Status: In Stock
Product codes
Attach a PC VGA port to a switchbox. This 10-foot VGA Video Monitor Cable features two HDDB15 (male) connectors, providing a high quality VGA connection.
The cable supports a maximum video resolution of up to 800x600. For applications that require higher resolutions, see 10ft Coax VGA Cable (MXT101MMHQ10).
Product Description StarTech.com 10 ft. (3 m) VGA to VGA Cable - HD15 VGA Cable - 800x600 Resolution - Male/Male - VGA Monitor Cable (MXT101MM10) - VGA cable - 3 m
Type VGA cable
Technology Shielded
Length 3 m
Connector HD-15 (VGA) - male
Connector (Second End) HD-15 (VGA) - male
Compliant Standards FCC
Colour Grey
Designed For P/N: CDP2VGA, CDP2VGAFC, SV231DVGAU2A, SV431DVGAU2A
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10 ft VGA...
£5.37
