StarTech.com 10 ft VGA Monitor Extension Cable - HD15 M/F
£5.02
42 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Guaranteed reliability
  • Length: 3m
  • Stock Status: In Stock
Product codes
Extend your VGA monitor connections by 10ft. This 10ft SVGA/VGA monitor extension cable lets you extend your VGA cable connection by 15ft.
The cable supports a maximum video resolution of up to 800x600. For applications that require higher resolutions, see 10ft Coax VGA Extension Cable (MXT101HQ10).
Product Description StarTech.com 10 ft VGA Monitor Extension Cable - HD15 M/F - Supports resolutions up to 800x600 (MXT10110) - VGA extension cable - 3 m
Type VGA extension cable
Length 3 m
Connector HD-15 (VGA) - male
Connector (Second End) HD-15 (VGA) - female
Compliant Standards RoHS
Colour Grey
Designed For P/N: DP2VGAMM6, DP2VGAMM6B, HD2VGAMM6, MXT101MM
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10 ft VGA...
£5.02
