This TAA compliant 10-port industrial USB 3.0 hub gives you the scalability and power supply flexibility you need in harsh industrial environments, product, and repair labs, conference rooms or office workstations. With its rugged industrial-grade metal housing, it is designed to meet the advanced requirements of connecting a high number of devices in factories and office environments.
This industrial USB hub delivers reliable performance with a metal, heavy-duty housing. It supports wide-range 10-24V DC terminal block input, giving you the flexibility to power the hub as required, based on your own power input capabilities.
Perfect for factory environments, the rugged hub also supports a wide operating temperature range (0°C to 70°C) and offers surge and ESD protection to each USB port, which can help prevent damage to your connected devices.
Designed for a high volume of connections, this robust USB 3.0 hub offers 10 connection ports, for connecting more USB devices and peripherals.
The hub also supports USB battery charging specification 1.2, delivering up to 2.4A on any port to a maximum of 50W total, so you can charge your mobile devices faster than traditional USB ports allow.
With versatile installation options, you can install the hub where it's best suited for your environment. With built-in mounting brackets and included DIN mount rails, you can securely mount the USB 3.0 hub to most surfaces such as a wall, under a desk or rack.
It supports wide-range 10-24V DC terminal block input, giving you the flexibility to power the hub as required, based on your own power input capabilities. You have the option to power the industrial hub by connecting the hub directly to an outlet with the included external terminal block power adapter, for more convenient and flexible installation.
The rugged USB hub supports the full 5Gbps bandwidth of USB 3.0 and is backward compatible with previous USB devices. You can connect your legacy peripherals alongside your newer USB 3.0 devices without any disruptions.
Product Description | StarTech.com 10 Port USB Hub with Power Adapter, Surge Protection, Metal Industrial USB 3.0 Data Transfer Hub, Din Rail, Wall or Desk Mountable, High Speed USB 3.1/ USB 3.2 Gen 1 5Gbps Hub - Windows/macOS/Linux (HB30A10AME) - hub - 10 ports - TAA Compliant | Device Type | Hub - 10 ports | Subtype | USB | Ports | 10 x USB 3.2 Gen 1 | Features | Surge protection, Unified Fabric Port (UFP), Dynamic Fabric Provisioning (DFP), 8KV ESD Protector (contact discharge), 15KV ESD Protector (air-gap discharge) | Compliant Standards | USB 1.1, USB 2.0, USB 3.0, USB 3.2 Gen 1 | Power | AC 120/230 V | Dimensions (WxDxH) | 13.3 cm x 61.5 cm x 31.3 cm | Weight | 350 g | Colour | Black | Localisation | Australia, Japan, New Zealand, United Kingdom, Europe, North Asia | TAA Compliant | Yes | Manufacturer Warranty | 2-year warranty | Designed For | P/N: ITB20D3250 |
General | |
Enclosure Type | DIN rail mountable, wall-mountable |
Subtype | USB |
Processor | X Genesys Logic GL3523 |
Expansion / Connectivity | |
Interfaces | 10 x USB 3.2 Gen 1 Type A , 1 x USB 3.2 Gen 1 Type B |
Power | |
Power Device | External power adapter |
Power Provided | DC 20 V - 3.25 A |
Voltage Required | AC 120/230 V |
Power Consumption Operational | 65 Watt |
Miscellaneous | |
Colour | Black |
Included Accessories | Mounting screws, DIN-rail mounting kit |
Cables Included | 1 x USB host cable |
MTBF | 126,106 hours |
Compliant Standards | FCC, REACH, USB Battery Charging Specification Rev. 1.2, UASP (USB Attached SCSI Protocol) |
Dimensions & Weight | |
Width | 13.3 cm |
Depth | 61.5 cm |
Height | 31.3 cm |
Weight | 350 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 85 °C |
Compatibility Information | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
