StarTech.com 100 ft Coax High Resolution Monitor VGA Cable -...
StarTech.com 100 ft Coax High Resolution Monitor VGA Cable -  HD15 M/M
£61.36
Delivery:
Standard: 1-3 working days
Product codes
This 100ft High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications (1024x768 and above), this high quality coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends. A reliable solution for a wide range of applications, this high resolution VGA (SVGA) cable features two hd15 male connectors and provides a connection distance of 100ft.
StarTech.com 100 ft Coax High Resolution Monitor VGA Cable - HD15 M/M - VGA cable - 30.5 m
VGA cable
Coaxial
Length
30.5 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
FCC
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 100 ft Co...
£61.36
