StarTech.com 100 ft Coax High Resolution Monitor VGA Cable -...
StarTech.com 100 ft Coax High Resolution Monitor VGA Cable -  HD15 M/M
£68.42
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
  • Length: 30.5m
  • Stock Status: In Stock
Product codes
This 100ft High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications (1024x768 and above), this high quality coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends. A reliable solution for a wide range of applications, this high resolution VGA (SVGA) cable features two hd15 male connectors and provides a connection distance of 100ft.
Product Description StarTech.com 100 ft Coax High Resolution Monitor VGA Cable - HD15 M/M - VGA cable - 30.5 m
Type VGA cable
Technology Coaxial
Length 30.5 m
Connector HD-15 (VGA) - male
Connector (Second End) HD-15 (VGA) - male
Compliant Standards FCC
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 100 ft Co...
£68.42
