StarTech.com 100 ft Coax High Resolution VGA Monitor Extensio...
StarTech.com 100 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F
£70.02
Delivery:
Key features
  • Ideal for high resolution monitors (1920x1200 and above)
  • Triple-coaxial + twisted-pair wire for crystal clear display
  • Impedance matched at 75 Ohms for full brightness and vibrant picture color
  • Type: SVGA
  • Length: 30.4m
Product codes
Documents
This 100ft High Resolution VGA Extension Cable is designed to provide the highest video quality possible through VGA.
Ideally suited for high resolution VGA applications, this high quality male to female coaxial VGA extension cable helps to eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
Product Description StarTech.com Coax High Resolution VGA Monitor Extension Cable - VGA extension cable - 30.4 m
Type VGA extension cable
Technology Coaxial
Features Molded
Length 30.4 m
Connector HD-15 (VGA) - male
Connector (Second End) HD-15 (VGA) - female
Designed For P/N: ST128UTPEAGB, ST122VGAU, ST128WGB, ST124WGB, ST122WGB, ST128UTPEA, ST128W, ST124W, ST122W, ST128UTPE, ST124UTPE, ST224MXGB, ST122PROAGB, ST124PROGB, ST122PROGB, ST128GB, ST222MX, ST122PROA, ST1216PRO, ST128PRO, ST122PRO, ST124PRO, ST128
Resources
The following resources are available for the StarTech.com 100 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 100 ft Co...
£70.02
