StarTech.com 1000 ft Bulk Roll of Blue CMR Cat5e Solid UTP Cable
£145.62
Colours:
Delivery:
Standard: 1-3 working days
Key features
  • Enjoy the low cost savings of buying bulk
  • Rated to 350Mhz which exceeds Cat 5e standards
  • Convenient measurement of cable runs
  • Length: 305m
  • Colour: Blue
  • Stock Status: In Stock
Product codes
Make reliable Ethernet connections in applications requiring CMR-rated cable. This Cat5e 350MHz Solid UTP Cable is CMR rated for use in walls, conduit, ceilings, etc. and is packaged as a 1000ft bulk roll. The cable features a blue PVC jacket, which provides both flexibility and durability, while making it easier to color code network cable connections.
Product Description StarTech.com 1000ft CAT5e Ethernet Cable - Blue - Bulk Roll - Solid UTP Cable - CMR Rated - Box of CAT5e Network Wire Cable (WIRC5ECMR) - bulk cable - 305 m - blue
Type Bulk cable - CAT 5e
Technology Unshielded twisted pair (UTP)
Features Solid
Length 305 m
Colour Blue
Package Type Bulk
Designed For P/N: POEEXT1GAT, POEEXT2GAT, ST1000SPEX2, ST1000SPEX2L, ST1000SPEXI, ST121HDWP, ST5GPEXNB, STUTPWALLA, USB2001EXT2P, USB2001EXTV
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1000 ft B...
£145.62
