StarTech.com 1000 ft Bulk Roll of Gray CMR Cat5e Solid UTP Cable
£147.42
Colours:
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Rated to 350Mhz which exceeds Cat 5e standards
  • Enjoy the low cost savings of buying bulk
  • Convenient measurement of cable runs
  • Length: 304.8m
  • Colour: Grey
  • Stock Status: In Stock
Product codes
Make reliable Ethernet connections in applications requiring CMR-rated cable. The WIRC5ECMRGRY Cat5e 350MHz Solid UTP Cable (Gray) is CMR rated for use in walls, conduit, ceilings, etc. and is packaged as a 1000-foot bulk roll. The cable features a gray PVC jacket, which provides both flexibility and durability, while making it easier to color code network cable connections.
Product Description StarTech.com 1000 ft Bulk Roll of Gray CMR Cat5e Solid UTP Cable - RJ45 Patch Cable - Cat 5e Patch Cable - Cat5e Patch Cable (WIRC5ECMRGRY) - bulk cable - 304.8 m - grey
Type Bulk cable - CAT 5e
Technology Unshielded twisted pair (UTP)
Wires per Cable 8 wires
Features Solid
Length 304.8 m
Colour Grey
Designed For P/N: ST121HDWP, STUTPWALLA, USB110EXT2
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1000 ft B...
£147.42
