StarTech.com 1000 Mbps Gigabit Ethernet Multi Mode SC Fiber P...
StarTech.com 1000 Mbps Gigabit Ethernet Multi Mode SC Fiber PCI Express Card - 550m
£135.06
Delivery:
Standard: 1-3 working days
Key features
  • 1000Mbps-full-duplex
  • Advanced Configuration Power Management Interface (ACPI) 2.0
  • Cable diagnostic utility
  • Compliant with RFC 1157 SNMP v1 which allows you to manage remotely
  • Complies with IEEE 802.1Q, 802.1p, 802.3ab standards
  • Microsoft NDIS5 (IP, TCP, UDP) checksum offload
  • PCI Express 1.0a compliant
Product codes
Add a gigabit Multi-mode SC fiber port to your system through PCI Express. The PEX1000MMSC 1000 Mbps Gigabit Ethernet Multi Mode SC Fiber PCI Express Card - 550m offers the perfect "Fiber-to-the-desk" solution, turning an available PCIe slot into an SC Multimode fiber connection. A simple solution for connecting a computer directly to a high-speed fiber network, the Fiber Gigabit Ethernet Adapter card is perfectly suited to high bandwidth applications with support for Full Duplex operation and gigabit transfer speeds. Ideal for secure network setups, the PEX1000MMSC offers a direct fiber connection which is not susceptible to electronic interference like standard RJ45 networks.
StarTech.com 1000 Mbps Gigabit Ethernet MM SC Fiber PCI Express Card - network adapter
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
PCI Specification Revision
PCIe 1.0a
Ports
1000Base-FX
2 cm x 10.9 cm x 8.3 cm
80 g
Cabling Type
Ethernet 1000Base-FX
GigE
Max Transfer Distance
550 m
IEEE 802.3z, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP)
Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1000 Mbps...
£135.06
