StarTech.com 1000 Mbps Gigabit Single-Mode Fiber Ethernet Med...
StarTech.com 1000 Mbps Gigabit Single-Mode Fiber Ethernet Media Converter SC 15km
Key features
  • Compact, lightweight design ensures portability and simplifies mounted installations
  • Easily installed into any scenario with little to no configurations needed
  • Free Lifetime Technical Support
Product codes
The MCMGBSC15GB Ethernet Media Converter converts transparently to/from 1000Base-T Ethernet signals and 1000Base-LH optical signals, providing a cost-effective Ethernet-fiber/copper-fiber link, in order to extend an Ethernet network connection over a Single Mode fiber backbone. Supporting a maximum Single Mode fiber optic cable distance of 15km (9.32 miles), the Fiber Media Converter delivers a simple solution for connecting Gigabit Ethernet networks to remote locations using SC-terminated SM fiber, while ensuring solid network performance and scalability.
StarTech.com 1000 Mbps Gigabit SM Fiber Ethernet Media Converter SC - fibre media converter
Fibre media converter - RJ-45 / SC single-mode
External
United Kingdom
Cabling Type
1000Base-LX, 1000Base-T
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
Max Transfer Distance
15 km
7.3 cm x 9.9 cm x 2.7 cm
450 g
1 year warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1000 Mbps...
