StarTech.com 1000 Mbps Gigabit Single Mode Fiber Media Conver...
StarTech.com 1000 Mbps Gigabit Single Mode Fiber Media Converter LC 40 km
£337.40
Delivery:
Standard: 1-3 working days
Key features
  • Cost-effective way to extend/bridge networks using fiber cabling
  • Link loss forwarding, remote monitoring of status ensures maximum up-time
  • Provides Ethernet to Fiber conversion as a standalone device, or can be installed into the ETCHS2U 20 slot chassis for added versatility
  • Rugged steel casing for added durability in harsh environments
  • Type: Media Converter
  • Stock Status: In Stock
Product codes
Convert and extend a Gigabit Ethernet connection up to 24.8 miles/40km over Single Mode LC fiber. The ET1000S40LC2 1000 Mbps Gigabit Single-Mode Fiber Media Converter (LC, 40 km) enables you to extend a Gigabit Ethernet network over single-mode fiber, at distances up to 40km (25 miles).
A cost-effective solution for connecting a Gigabit Ethernet (1000Base-T) network to remote network segments over a (1000Base-LX/SX) fiber backbone, the GbE to SM fiber converter supports full Gigabit speeds for ideal network performance and scalability. Designed to offer a durable and convenient Ethernet to fiber solution, the Ethernet to LC Fiber converter features an all-steel chassis, and a simple plug-and-play installation with minimal configuration required.
For added versatility, this fiber media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U).
Product Description StarTech.com 1000 Mbps Gigabit Single-Mode Copper to Fiber Media Converter - Ethernet (1000Base-T) to LC Fiber Converter (ET1000S40LC2) - fibre media converter - GigE
Device Type Fibre media converter - RJ-45 / LC single-mode
Form Factor External
Localisation North America, United Kingdom, Europe
Cabling Type 1000Base-LX, 1000Base-SX, 1000Base-T
Data Transfer Rate 1 Gbps
Optical Wave Length 1310 nm
Data Link Protocol GigE
Max Transfer Distance 40 km
Power AC 120/230 V
Dimensions (WxDxH) 9.5 cm x 16 cm x 2 cm
Weight 0.62 kg
Designed For P/N: SVA12M2NEUA, SVA12M5NA
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1000 Mbps...
£337.40
