StarTech.com 1000Base-EX SFP - SM LC- 40 km
£61.96
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Delivers reliable 1 GbE connections for 1000BASE-EX compliant networks
  • StarTech.com SFP modules are backed by a lifetime warranty
  • Complies with Multi-Source Agreement (MSA) industry standards
Product codes
Add reliable and cost-effective Gigabit Ethernet connections over single-mode fiber, with this SFP module. This 1000Base-EX SFP module delivers what you need most in your network connections: reliable performance. It's built to exacting MSA specifications and fully tested to ensure seamless compatibility. The single-mode SFP transceiver module offers a cost-effective way to add, replace or upgrade the ports on your networking equipment.
With data transfer rates of up to 1Gbps and support for Digital Diagnostics Monitoring (DDM / DOM), this LC SFP module can be installed into fiber networking equipment with an MSA compliant port. It delivers dependable Gigabit connectivity over single-mode fiber for 1000Base-EX compliant networks, with a maximum distance of up to 40 km (24.8 mi.) and 1310 nm optical wavelength.
This optical transceiver is engineered to meet or exceed the industry's MSA (Multi-Source Agreement) standards. StarTech.com brings its established reputation for high-quality connectivity solutions to SFP transceivers, providing SFPs that match major OEM brands in performance and reliability. Committed to the highest standards, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile solution that's compatible with a wide range of networking equipment, allowing you to expand your network to remote segments cost-effectively.
StarTech.com 1000BASE-EX Fiber SFP Module - Lifetime Warranty - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-EX
Data Transfer Rate
1.25 Gbps
Optical Wave Length
1310 nm
GigE
Max Transfer Distance
40 km
1.39 cm x 5.84 cm x 1.26 cm
30 g
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1000Base-...
£61.96
