We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Add reliable and cost-effective 100-Mbps Ethernet connections over single-mode fiber, with this SFP module. This 100Base-BX (downstream) SFP module delivers what you need most in your network connections: reliable performance. It's built to exacting MSA specifications and fully tested to ensure seamless compatibility. The single-mode SFP transceiver module offers a cost-effective way to add, replace or upgrade the ports on your networking equipment.
With data transfer rates of up to 100Mbps and support for Digital Diagnostics Monitoring (DDM / DOM), this LC SFP module can be installed into fiber networking equipment with an MSA compliant port. It delivers dependable Fast Ethernet connectivity over single-mode fiber for 100Base-BX compliant networks, with a maximum distance of up to 10 km (6.2 mi.) and 1550nm Tx / 1310nm Rx optical wavelength.
This optical transceiver is engineered to meet or exceed the industry's MSA (Multi-Source Agreement) standards. StarTech.com brings its established reputation for high-quality connectivity solutions to SFP transceivers, providing SFPs that match major OEM brands in performance and reliability. Committed to the highest standards, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile solution that's compatible with a wide range of networking equipment, allowing you to expand your network to remote segments cost-effectively.
Product Description | StarTech.com MSA Uncoded SFP Module, 100BASE-BX, 100Mb Ethernet Bi-Directional (BiDi) Fiber Single Strand SFP Transceiver (SMF), LC 10km , Mini GBIC Transceiver SFP Module, Downstream - Lifetime Warranty (SFP100BBXDST) - SFP (mini-GBIC) transceiver module - 100Mb LAN | Device Type | SFP (mini-GBIC) transceiver module - LC single-mode | Form Factor | Plug-in module | Cabling Type | 100Base-BX | Data Transfer Rate | 100 Mbps | Optical Wave Length | 1550 (TX) / 1310 (RX) nm | Data Link Protocol | 100Mb LAN | Max Transfer Distance | 10 km | Dimensions (WxDxH) | 1.39 cm x 5.84 cm x 1.26 cm | Weight | 30 g | Manufacturer Warranty | Limited lifetime warranty |
General | |
Device Type | SFP (mini-GBIC) transceiver module |
Colour | Silver |
Networking | |
Connectivity Technology | Wired |
Features | Digital Optical Monitoring (DOM) support, Digital Diagnostics Monitoring (DDM) |
Compliant Standards | IEEE 802.3u |
Expansion / Connectivity | |
Interfaces | 1 x Ethernet 100Base-BX - LC single-mode |
Miscellaneous | |
Compliant Standards | cUL, FCC, RoHS, WEEE, MSA |
Dimensions & Weight | |
Width | 1.39 cm |
Depth | 5.84 cm |
Height | 1.26 cm |
Weight | 30 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Humidity Range Operating | 5 - 95% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
