StarTech.com 100Mbps PCI Multi Mode ST Fiber Ethernet NIC Net...
StarTech.com 100Mbps PCI Multi Mode ST Fiber Ethernet NIC Network Adapter 2km
£89.58
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Ideal for secure setups - Direct fiber means no electronic interference like standard RJ45 network cards
  • Versatile and comprehensive transfer support with Full Duplex 10/100 Mbps transfer speeds
  • Retain full speed to a remote terminal over distances of up to 2km
Product codes
Connect a PC directly to a multimode ST fiber network through an available PCI slot. The PCI100MMST 100 Mbps Fiber Optic (MM ST) PCI Ethernet Adapter Card offers the perfect "Fiber-to-the-desk" solution allowing you to add a multimode ST fiber port to your system through an available standard or low-profile PCI slot.
A simple solution for connecting a computer directly to a fiber network, the Fiber Ethernet Adapter card can be installed in the computer through any PCI slot and is perfectly suited for high bandwidth applications with support for Full Duplex operation and 10/100 Mbps transfer speeds at distances of up to 2km.
Ideal for secure network setups, the PCI100MMST offers a direct fiber connection which is not susceptible to electronic interference like standard RJ45 networks.
Product Description StarTech.com 100Mbps PCI Multi Mode ST Fiber Ethernet NIC Network Adapter 2km - network adapter
Device Type Network adapter
Form Factor Plug-in card - low profile
Interface (Bus) Type PCI-X / 133 MHz
Ports 10/100 Ethernet
Dimensions (WxDxH) 5.6 cm x 12.1 cm x 1.8 cm
Cabling Type Ethernet 100Base-FX
Data Link Protocol 10Mb LAN, 100Mb LAN
Data Transfer Rate 100 Mbps
Compliant Standards IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 100Mbps P...
£89.58
