We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Install this single-port 10GbE PCI Express (PCIe) Network Interface Card (NIC) into a server or computer to enable faster network speeds and enhanced network functionality. This card supports six speeds: 10/5/2.5/1Gbps and 100/10Mbps. The variable speeds permit access to legacy hardware. Alternatively, the 10GBASE-T and NBASE-T capabilities ensure compatibility with the latest network switches and network access points manufactured by Cisco ; HPE ; and Aruba .
Product Description | StarTech.com 1-Port 10Gbps PCIe Network Adapter Card, Network Card for PC/Server, Low Profile PCIe Ethernet Card w/Jumbo Frame Support, NIC/LAN Interface Card - Marvell AQC113CS Chipset, PXE Boot (ST10GSPEXNB2) - network adapter - PCIe 3.0 x2 - 10 Gigabit Ethernet x 1 | Device Type | Network adapter | Form Factor | Plug-in card | Interface (Bus) Type | PCI Express 3.0 x2 | PCI Specification Revision | PCIe 3.0, PCIe 4.0 | Ports | 10 Gigabit Ethernet x 1 | Dimensions (WxDxH) | 1.5 cm x 10.6 cm x 5.6 cm | Weight | 73 g | Cabling Type | NBase-T | Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE, 10 GigE, 5 GigE, 2.5 GigE | Data Transfer Rate | 10 Gbps | Network / Transport Protocol | TCP/IP, UDP/IP | Processor | 1 x Marvell AQC113CS | Compliant Standards | IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3an, IEEE 802.3bz, IEEE P802.3az | Colour | Black | System Requirements | Windows 8 / 10 / 11, Linux 3.10.x or later LTS versions only | Manufacturer Warranty | 2-year warranty |
General | |
Networking | |
Connectivity Technology | Wired |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet, 5 Gigabit Ethernet, 2.5 Gigabit Ethernet |
Status Indicators | Link/activity |
Features | Full duplex capability, secure boot, Energy-Efficient Ethernet (EEE), 16 KB Jumbo Frame, VLAN Tagging, Audio Video Bridging (AVB), Automatic Media-Dependent Interface Crossover (MDIX), PXE boot |
Processor / Memory | |
Expansion / Connectivity | |
Interfaces | 1 x 100M/1G/2.5/5/10 Gigabit Ethernet - RJ-45 |
Miscellaneous | |
Included Accessories | Low-profile bracket |
Compliant Standards | RoHS, RCM |
Colour | Black |
Software / System Requirements | |
OS Required | Windows 8 / 10 / 11, Linux 3.10.x or later LTS versions only |
Dimensions & Weight | |
Width | 1.5 cm |
Depth | 10.6 cm |
Height | 5.6 cm |
Weight | 73 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 3.5 cm |
Shipping Depth | 21 cm |
Shipping Height | 14.5 cm |
Shipping Weight | 151 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years , Technical support - assistance - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
