Install this 2-port 10GbE PCI Express (PCIe) Network Interface Card (NIC) into a server or computer to enable fast network speeds and enhanced network functionality by providing failover and redundancy protection to mission-critical servers/applications. This Card supports six speeds: 10/5/2.5/1Gbps and 100/10Mbps with auto-negotiation for instant compatibility with new and legacy hardware. In addition, 10GBASE-T and NBASE-T (2.5GBASE-T/5GBASE-T) capabilities ensure compatibility with the latest network switches and access points manufactured by Cisco ; HPE ; and Aruba Networks .
Product Description | StarTech.com 2-Port 10Gbps PCIe Network Adapter Card, Network Card for PCs/Servers, Full-Height/Low-Profile PCIe Ethernet Card w/Jumbo Frames, NIC/LAN Interface Card - Marvell AQC113CS Chipset, PXE Boot (ST10GSPEXNDP2) - network adapter - PCIe 3.0 x4 - 10 Gigabit Ethernet x 2 | Device Type | Network adapter | Form Factor | Plug-in card - low profile | Interface (Bus) Type | PCI Express 3.0 x4 | PCI Specification Revision | PCIe 3.0, PCIe 4.0 | Ports | 10 Gigabit Ethernet x 2 | Dimensions (WxDxH) | 2 cm x 14.5 cm x 6.5 cm | Weight | 116 g | Cabling Type | Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 10GBase-T, Ethernet 2.5GBase-T, Ethernet 5GBase-T, NBase-T | Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE, 10 GigE, 5 GigE, 2.5 GigE | Data Transfer Rate | 10 Gbps | Capacity | Jumbo frame size: 16000 | Network / Transport Protocol | TCP/IP, UDP/IP | Processor | 1 x Marvell AQC113CS | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3an, IEEE 802.3bz, IEEE P802.3az | Colour | Black | System Requirements | Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux 3.10.x or later LTS versions only, Windows 8 / 8.1 / 10 / 11 | Manufacturer Warranty | 2-year warranty |
General | |
Networking | |
Connectivity Technology | Wired |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet, 5 Gigabit Ethernet, 2.5 Gigabit Ethernet |
Status Indicators | Link/activity |
Features | Full duplex capability, wake on LAN (WOL), PXE support, Precision Time Protocol (PTP), secure boot, Energy-Efficient Ethernet (EEE), VLAN Tagging, Audio Video Bridging (AVB), promiscuous mode, Automatic Media-Dependent Interface Crossover (MDIX), PXE boot |
Processor / Memory | |
Expansion / Connectivity | |
Interfaces | 2 x 10M/100M/1G/2.5/5/10 Gigabit Ethernet - RJ-45 |
Miscellaneous | |
Included Accessories | Low-profile bracket, full-height bracket |
Compliant Standards | FCC, RCM |
Colour | Black |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux 3.10.x or later LTS versions only, Windows 8 / 8.1 / 10 / 11 |
Dimensions & Weight | |
Width | 2 cm |
Depth | 14.5 cm |
Height | 6.5 cm |
Weight | 116 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 14.5 cm |
Shipping Depth | 21.5 cm |
Shipping Height | 3.5 cm |
Shipping Weight | 208 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years , Technical support - assistance - lifetime |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 20 - 80% RH |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
