StarTech.com 10GBase-ZR SFP+ - SM LC 80 km
£1,163.54
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Delivers reliable 10 GbE connections for 10GBASE-ZR compliant networks
  • StarTech.com SFP modules are backed by a lifetime warranty
  • Complies with Multi-Source Agreement (MSA) industry standards
  • Stock Status: In Stock
Product codes
Add reliable and cost-effective 10 Gigabit Ethernet connections over single-mode fiber, with this SFP+ module. This 10GBase-ZR SFP+ module delivers what you need most in your network connections: reliable performance. It's built to exacting MSA specifications and fully tested to ensure seamless compatibility. The single-mode SFP+ transceiver module offers a cost-effective way to add, replace or upgrade the ports on your networking equipment.
With data transfer rates of up to 10Gbps and support for Digital Diagnostics Monitoring (DDM / DOM), this LC SFP+ module can be installed into fiber networking equipment with an MSA compliant port. It delivers dependable 10 Gigabit connectivity over single-mode fiber for 10GBase-ZR compliant networks, with a maximum distance of up to 80 km (49.7 mi.) and 1550 nm optical wavelength.
This optical transceiver is engineered to meet or exceed the industry's MSA (Multi-Source Agreement) standards. StarTech.com brings its established reputation for high-quality connectivity solutions to SFP transceivers, providing SFPs that match major OEM brands in performance and reliability. Committed to the highest standards, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile solution that's compatible with a wide range of networking equipment, allowing you to expand your network to remote segments cost-effectively.
Product Description StarTech.com 10GBASE-ZR SFP+ Transceiver Module - 10 Gbps - 80 km - MSA Compliant Fiber SFP+ (SFP10GBZRST) - SFP+ transceiver module - 10 GigE
Device Type SFP+ transceiver module - LC single-mode
Form Factor Plug-in module
Cabling Type 10GBase-ZR
Data Transfer Rate 10 Gbps
Optical Wave Length 1550 nm
Data Link Protocol 10 GigE
Max Transfer Distance 80 km
Dimensions (WxDxH) 1.39 cm x 5.84 cm x 1.26 cm
Weight 30 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10GBase-Z...
£1,163.54
