StarTech.com 10m 10G SFP+ Active DAC Cable
£135.16
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • 100% compatibility with Cisco SFP-H10GB-ACU10M guaranteed
  • StarTech.com SFP cables are backed by a lifetime warranty
  • Uses a cost-effective cabling alternative to fiber-optic setups
  • Length: 10m
  • Colour: Black
Product codes
Connect your Cisco 10GbE SFP+ network devices with this cost-effective, active Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
The active twinaxial cable is a fully hot-pluggable solution, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for high-speed interconnects, this cable is intended for medium-distance applications such as across-rack network switch or server connections.
Product Description StarTech.com Cisco SFP-H10GB-ACU10M Compatible 10m 10G SFP+ to SFP+ Direct Attach Cable Twinax, 10GbE SFP+ Copper DAC 10Gbps Low Power Active Transceiver Module DAC Cable, Firepower ASR9000 - Lifetime Warranty (SFPH10GACU10) - 10GBase direct attach cable - 10 m - black
Type 10GBase direct attach cable - SFF-8431/SFF-8432
Technology Twinaxial
Features Active cable
Length 10 m
Connector SFP+ - latched
Connector (Second End) SFP+ - latched
Colour Black
OEM Manufacturer Equivalent Part Number Cisco SFP-H10GB-ACU10M
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£135.16
