StarTech.com 10m/30ft Active USB 2.0 A to B Cable - M/M
£20.29
Select:
Delivery:
Standard: 1-3 working days
Key features
  • Designed to exceed standard USB 2.0 cable lengths, the signal is automatically re-equalized to reach greater distances
  • A high quality replacement for worn-out or missing USB cables
  • Backed by StarTech.com 2 Year warranty
  • Length: 9.15m
  • Stock Status: In Stock
Product codes
Extend the distance between your USB 2.0 devices to 30ft. The USB2HAB30AC 30-foot USB A to B cable features one USB type-A (male) connector and one USB type-B (male) connector, providing a high quality connection to USB 2.0 peripherals.
This 30-foot USB cable incorporates an equalizing chip, which enables it to perform beyond the limits of standard USB cables and communicate with peripherals up to 30ft away. Expertly designed with top quality materials for high durability.
Product Description StarTech.com 9 m / 30 ft Active USB A to B Cable - M/M - Black USB 2.0 A to B Cord - Printer Cable - Extension USB Cable (USB2HAB30AC) - USB cable - 9.15 m
Type USB cable
Technology Shielded
Features Active cable (signal regeneration)
Length 9.15 m
Connector 4 pin USB Type A - male
Connector (Second End) 4 pin USB Type B - male
Compliant Standards USB / USB 2.0
Colour Black
Designed For P/N: ICUSB232D
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10m/30ft...
£20.29
