StarTech.com 10m 40G QSFP+ Active DAC Cable
£557.42
Select:
Delivery:
Key features
  • 100% compatibility with Cisco QSFP-H40G-ACU10M guaranteed
  • StarTech.com SFP cables are backed by a lifetime warranty
  • Uses a cost-effective cabling alternative to fiber-optic setups
Product codes
Connect your Cisco 40GbE QSFP+ network devices with this cost-effective, active Twinax copper cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
The active twinaxial cable is a fully hot-pluggable solution, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports.
Designed for high-speed interconnects, this cable is intended for medium-distance applications such as across rack network switch or server connections.
StarTech.com 10m 33 ft Cisco QSFP-H40G-ACU10M Compatible - QSFP+ DAC Cable - 40GBase direct attach cable - 10 m - black
40GBase direct attach cable - SFF-8436
Twinaxial
Active cable
Length
10 m
Connector
QSFP+ - latched
Connector (Second End)
QSFP+ - latched
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10m 40G Q...
£557.42
