StarTech.com 10m Black Gigabit Snagless RJ45 UTP Cat6 Patch C...
StarTech.com 10m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable - 10 m Patch Cord
£9.16
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 50-micron gold connectors ensure optimum conductivity while eliminating signal loss due to oxidation or corrosion
  • Backed by StarTech.com lifetime warranty
  • RJ45 connector clip protectors help keep the plugs from snagging while routing the cable, for easier Cat 6 cable runs
  • Length: 10m
  • Colour: Black
  • Stock Status: In Stock
Product codes
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC10MBK Cat 6 Patch Cable (10m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable black PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
Product Description StarTech.com 10m Black Cat6 / Cat 6 Snagless Patch Cable - patch cable - 10 m - black
Type Patch cable - CAT 6
Technology Unshielded twisted pair (UTP)
Features Molded, snagless
Length 10 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10m Black...
£9.16
