StarTech.com 10m Coax High Resolution Monitor VGA Cable - HD1...
StarTech.com 10m Coax High Resolution Monitor VGA Cable - HD15 M/M
£27.98
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Backed by StarTech.com's Lifetime warranty
  • Delivers high resolution from your PC to your VGA display (1920x1200 or above)
  • Extends your VGA signal to work with your monitor, splitters, and projectors
  • Length: 10m
  • Stock Status: In Stock
Product codes
Connect your VGA monitor with the highest quality connection available. This 10m high resolution VGA monitor cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male-to-male coaxial VGA cable eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
Product Description StarTech.com 10m Coax High Resolution Monitor VGA Cable HD15 M/M - VGA cable - 10 m
Type VGA cable
Technology Triple shielded twisted pair coaxial
Features Molded
Length 10 m
Connector HD-15 (VGA) - male
Connector (Second End) HD-15 (VGA) - male
Compliant Standards RoHS
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10m Coax...
£27.98
