StarTech.com 10m Coax High Resolution Monitor VGA Video Exten...
StarTech.com 10m Coax High Resolution Monitor VGA Video Extension Cable - HD15 M/F
£27.98
Delivery:
Standard: 1-3 working days
Key features
  • Supports a VGA video signal that is ideal for high resolution monitors (1920x1200 and above)
  • Enables you to connect high resolution VGA monitors at longer distances, without sacrificing video quality
  • Backed by StarTech.com Lifetime warranty
  • Length: 10m
  • Stock Status: In Stock
Product codes
Extend your VGA monitor connection without losing video signal quality. The MXTHQ10M High Resolution VGA Extension Cable (10-meter) is designed to extend your VGA video connection while maintaining the highest video quality possible through VGA.
Ideally suited for high resolution VGA video applications, this high quality coaxial VGA extension cable (HD15 to HD15, M-F) helps eliminate the picture ghosting and fuzzy images that are inherent to non-coaxial cables, and features ferrite cores near the VGA connector ends to protect against EMI interference.
Product Description StarTech.com Coax High Resolution Monitor VGA Video Extension Cable - VGA extension cable - 10 m
Type VGA extension cable
Technology Triple shielded twisted pair coaxial
Features Molded, strain relief, ferrite core
Length 10 m
Connector HD-15 (VGA) - male
Connector (Second End) HD-15 (VGA) - female
Compliant Standards RoHS
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10m Coax...
£27.98
