StarTech.com 10m Red Cat5e Patch Cable
£6.00
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • RJ45 connector-clip protectors eliminate cable snags and breaks during installation
  • Red PVC jacket for color coding your connections
  • 10 meters in length for longer connections
  • Length: 10m
  • Colour: Red
  • Stock Status: In Stock
Product codes
Make Fast Ethernet connections with support for PoE. This Cat5e patch cable delivers reliable network connections, which ensures high-performance capability for your demanding Ethernet applications.
This 10-meter red network cable is perfect for use in network conduits and raceways. The cable is intended for longer distance applications, such as running up a post or throughout the office from a hub to a wall- jack.
For easier network installations, the Cat 5e cables are available in a wide variety of lengths and colors. This ensures you have the right size of cable available when you need it and it lets you color code your connections for a more organized setup.
For trouble-free cable runs, this durable cable features snagless connectors that protect the RJ45 clips during installation, making them less likely to snag or break.
The cable also features molded boots which offer connector strain relief by stopping the RJ45 connector termination points from bending at sharp angles. This reduces the risk of damage to the cable, which could decrease network connectivity and performance.
Get the highest value for your cable investment with the Cat5e Ethernet cables, each one manufactured using high-quality copper conductors. They are carefully constructed and tested, to keep Near-End Crosstalk (NEXT) well within acceptable limits.
Ensure high-performance capability for your demanding Ethernet applications, such as Power-over-Ethernet and 4K or 1080p video streaming, using cables that include 24 AWG copper.
You can rely on the RJ45 connectors to deliver optimum conductivity, while eliminating signal loss due to oxidation or corrosion.
Product Description StarTech.com CAT5e Cable - 10 m Red Ethernet Cable - Snagless - CAT5e Patch Cord - CAT5e UTP Cable - RJ45 Network Cable - patch cable - 10 m - red
Type Patch cable - CAT 5e
Technology Unshielded twisted pair (UTP)
Wires per Cable 8 wires
Features Snagless, minimised Near-End Crosstalk (NEXT)
Length 10 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Red
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10m Red C...
£6.00
