StarTech.com 10m Red Cat6 Patch Cable
£10.05
22 in stock
Delivery:
Standard: 1-3 working days
Key features
  • RJ45 connector clip protectors
  • Carefully constructed and tested, to keep Near End Crosstalk (NEXT) well within acceptable limits
  • Colored hoods for departmental color coding
Product codes
Make Power-over-Ethernet-capable Gigabit network connections. This 10-meter Cat6 cable meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections. Plus, the cable features a durable red PVC jacket that enables you to color code your network cable runs as needed.
For easier cable runs, the snagless connectors protect the cable's RJ45 clips during installation, making them less likely to snag or break. This ensures a sturdy connection by preventing the cable from becoming loose from the port.
The cable features molded boots that offer connector strain relief, by stopping the RJ45 connector termination points from bending at sharp angles, and reducing the risk of damage to the cable, which could decrease network performance.
StarTech.com 10m Red Cat6 / Cat 6 Snagless Patch Cable 10 m - patch cable - 10 m - red
Patch cable - CAT 6
Molded, snagless, strain relief, minimised Near-End Crosstalk (NEXT), kink protection, PoE ready
Length
10 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Red
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10m Red C...
£10.05
