StarTech.com 10m USB 3.0 Active Extension Cable - M/F
£98.92
Delivery:
Standard: 1-3 working days
Key features
  • Extends a USB 3.0 device connection by an additional 10m (33ft) or cascade up to 2 levels for 20m (65ft)
  • Powered directly from the USB port or through the included Universal external power adapter
  • Backed by a StarTech.com 2-year warranty and free lifetime technical support
  • Length: 10m
  • Stock Status: In Stock
Product codes
The USB3AAEXT10M, 10-meter Active USB 3.0 Extension Cable, offers one USB type-A (male) connector and one USB type-A (female) connector, and provides an active extension of USB 3.0 devices of up to 10-meters (32.8-feet).
An all-in-one cable for overcoming distance restrictions as well as power source limitations; the active USB 3.0 extension cable incorporates bus-powered active circuitry to ensure performance beyond the length limits of standard USB cables. Up to 2 of these cables can be daisy-chained together, allowing the connection to be extended a total of 20-meters. If necessary, the USB device can be powered from a wall outlet using the Universal AC power adapter provided with the cable.
The USB3AAEXT10M extension cable (USB Extender) supports high speed USB 3.0 transfer rates of up to 5Gbps.
Product Description StarTech.com 10m USB 3.0 Active Extension Cable - M/F - USB extension cable - 10 m
Type USB extension cable
Features Active cable (signal regeneration)
Length 10 m
Connector 9 pin USB Type A - male
Connector (Second End) 9 pin USB Type A - female
Compliant Standards USB / USB 2.0 / USB 3.0
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10m USB 3...
£98.92
