StarTech.com 120x25mm Computer Case Fan with PWM – Pulse Widt...
StarTech.com 120x25mm Computer Case Fan with PWM – Pulse Width Modulation Connector
£9.22
Delivery:
  • Type: Case Fan
Product codes
Add a variable speed, PWM-controlled cooling fan to your computer case. The FAN12025PWM 120mm PWM case fan adds an efficient air cooling solution to computer cases or other enclosures to help ensure optimal performance from internal components.
With Pulse Width Modulation (PWM) technology, the fan speed can be dynamically controlled by the motherboard, so the fan runs at a speed that suits the operating conditions - lowering power consumption and fan noise when the system is idle, and delivering maximum cooling under full load conditions.
Product Description StarTech.com 120x25mm Computer Case Fan with PWM - Pulse Width Modulation Connector - computer cooling Fan - pwm Fan - 120mm Fan (FAN12025PWM) case fan
Product Type Case fan
Package Content Y-Split cable
Colour Black
Fan Diameter 120 mm
Fan Height 25 mm
Fan Bearing Ever Lubricate bearing
Rotation Speed 800-2200 rpm
Air Flow 33.2-78.4 cfm
Noise Level 17.2 - 39 dBA
Power Connector 4-pin fan connector, 4 pin Molex connector
Dimensions (WxDxH) 12 cm x 12 cm x 2.5 cm
Weight 118 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 120x25mm...
£9.22
