StarTech.com 120x25mm Dual Ball Bearing Computer Case Fan wit...
StarTech.com 120x25mm Dual Ball Bearing Computer Case Fan with LP4 Connector
£9.38
15 in stock
Delivery:
Standard: 1-3 working days
  • Type: Case Fan
  • Stock Status: In Stock
Product codes
The StarTech.com 12cm x 12cm x 2.5cm (4 3/4" x 4 3/4" x 1") PC case fan is an add-in cooling fan designed to fit most computers. It can be used to circulate cool air into the case or exhaust warm air out, preventing problems due to overheating components. A quiet running brushless ball bearing DC motor coupled with a high efficiency blade design is capable of moving 48 CFM (cubic feet per minute) of air. Power is supplied to the fan using a standard LP4 (hard drive power connector) pass through plug.
Product Description StarTech.com 120x25mm Dual Ball Bearing Computer Case Fan w/ LP4 Connector system fan kit
Product Type System fan kit
Fan Diameter 120 mm
Noise Level 34 dBA
Dimensions (WxDxH) 12 cm x 2.5 cm x 12 cm
Weight 129 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 120x25mm...
£9.38
