This 13 ft (4 m) Ultra High-Speed HDMI Cable, withstands the daily demands of connecting your HDMI devices. Tested to endure strenuous wear and tear, this durable cable is a must-have for both business and consumer applications.
Product Description | StarTech.com 12ft (4m) HDMI 2.1 Cable, Certified Ultra High Speed HDMI Cable 48Gbps, 8K 60Hz/4K 120Hz HDR10+ eARC, Ultra HD 8K HDMI Cable/Cord w/TPE Jacket, For UHD Monitor/TV/Display - Dolby Vision/Atmos, DTS-HD (HDMM21V4M) - HDMI cable with Ethernet - 4 m | Cable | Ultra High Speed - HDMI cable with Ethernet | Technology | Shielded | American Wire Gauge (AWG) | 30/32 | Length | 4 m | Colour | Grey, black | Connector | HDMI - male | Connector (Second End) | HDMI - male | Features | Passive cable, 4K120Hz support, 8K60Hz (7680 x 4320) support | Manufacturer Warranty | Limited lifetime warranty |
General | |
Cable Type | Ultra High Speed - HDMI cable with Ethernet passive, 4K120Hz support, 8K60Hz (7680 x 4320) support |
Jacket Material | Thermoplastic elastomer (TPE) |
Shielding Material | Aluminum mylar foil with braid |
Length | 4 m |
Plated Connector | Gold |
Features | Dolby TrueHD support, Dolby DTS-HD Master Audio support, Dolby Atmos support, Enhanced Audio Return Channel (eARC), Dolby DTS:X support, Dolby Vision, 48Gbps support, support HDR10+, strain relief, 32 audio channels, outer diameter 6mm |
Connectivity | |
Connector | 19 pin HDMI Type A - male |
Connector (Second End) | 19 pin HDMI Type A - male |
Miscellaneous | |
Compliant Standards | RoHS, WEEE, EMI, HDCP 2.3 |
Dimensions & Weight (Shipping) | |
Shipping Width | 33 cm |
Shipping Depth | 25.2 cm |
Shipping Height | 6 cm |
Shipping Weight | 290 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
