StarTech.com 12in 4 Pin Fan Power Extension Cable - M/F
£4.28
40 in stock
Delivery:
Standard: 1-3 working days
  • Length: 3m
  • Stock Status: In Stock
Product codes
The FAN4EXT12 12-inch 4-Pin Fan Power Extension Cable lets you extend the power connection between a computer power supply and a 4-pin fan by up to 1ft, enabling you to conveniently install the fan where needed in the computer case, without having to stretch or strain the connection.
Product Description StarTech.com 12in 4 Pin Fan Power Extension Cable - M/F - Fan power extension cable - 4 pin PWM (M) to 4 pin PWM (F) - FAN4EXT12 - fan power extension cable - 3 m
Type Fan power extension cable
Length 3 m
Connector 4 pin PWM - male
Connector (Second End) 4 pin PWM - female
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 12in 4 Pi...
£4.28
