StarTech.com 12in 4 Pin Fan Power Splitter Cable - F/M
£5.47
14 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Allows you to connect two 4-pin (PWM) fans to a single motherboard fan power connector
  • Re-position your computer case fans to provide optimal cooling to your system
  • Backed by StarTech.com lifetime warranty
Product codes
Connect two 4-pin (PWM) Fans to a Single Motherboard Fan Power Connector. The FAN4SPLIT12 Fan Power Splitter Cable enables you to connect two 4-pin (PWM) fans to a single motherboard power connector, which allows you to optimize your computer cooling capability.
Providing a flexible way to position computer case fans as needed, this 4-pin Fan Power Splitter cable offers a connection length of 1ft, eliminating the need to strain the connection between the computer power connector and the fans.
This high quality splitter cable is constructed of high quality materials to ensure long-lasting performance.
StarTech.com 12in 4 Pin Fan Power Splitter Cable - F/M - fan power splitter - 31 cm
Fan power splitter
Length
31 cm
Connector
4 pin PWM - female
Connector (Second End)
2 x 4 pin PWM - male
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 12in 4 Pi...
£5.47
