StarTech.com 12in Latching SATA to Right Angle SATA Serial AT...
StarTech.com 12in Latching SATA to Right Angle SATA Serial ATA Cable
£4.08
15 in stock
Delivery:
Standard: 1-3 working days
  • Length: 30cm
  • Type: SATA
  • Stock Status: In Stock
Product codes
This 12in right-angled latching SATA cable features a (straight) female Serial ATA connector as well as a right-angled (female) SATA connector, providing a simple connection to a Serial ATA drive even if space near the drive's SATA port is limited. The cable offers latching connectors, which ensure secure connections for SATA hard drives and motherboards that support this feature. Once the right-angled SATA connector has been inserted into the drive's SATA data port, the shaft of the cable is seated flush with the rear panel of the drive, eliminating the clutter of excess cable at the connection point - an ideal solution for small or micro form factor computer cases. The right angled SATA cable features a thin, narrow construction that helps to improve airflow within the computer case; the cable features a rugged, yet flexible design that makes it easy to make the SATA connection as needed.
Product Description StarTech.com 12in Latching SATA to Right Angle SATA Serial ATA Cable (LSATA12RA1) - SATA cable - 30 cm
Type SATA cable
Interface Speed Serial ATA 150/300
Features Latched, right-angled connector
Length 30 cm
Connector 7 pin Serial ATA - female
Connector (Second End) 7 pin Serial ATA - female
Colour Red
Designed For P/N: 35S24M2NGFF, CFAST2SAT25, PEXSAT32, ST521PMINT, USB2SATAIDE, USB3SSATAIDE
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 12in Latc...
£4.08
