StarTech.com 12in LP4 to 2x Right Angle Latching SATA Power Y...
StarTech.com 12in LP4 to 2x Right Angle Latching SATA Power Y Cable Splitter - 4 Pin Molex to SATA
£4.64
13 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Cost-effective solution for powering two SATA drives from a single LP4 connection on the computer power supply, which eliminates the cost of a power supply upgrade for compatibility with SATA hard drives
  • Right-angled latching SATA cable connectors easily fit into hard to reach areas and tight spaces, and reduce the risk of accidental disconnections
  • Backed by StarTech.com lifetime warranty
  • Length: 30cm
  • Stock Status: In Stock
Product codes
Power two SATA drives from a single LP4 power supply connector. The PYO2LP4LSATR LP4 Molex to Dual Latching Right-Angle SATA power splitter cable features two Serial ATA female power connectors and one LP4 male connector - a reliable solution that enables you to power two SATA drives using a single LP4 connection to the computer power supply.
This durable LP4 to SATA Y cable adapter is 12 inches in length, giving you enough cable slack to position drives as needed within the computer case, while saving the cost and hassle of upgrading a power supply for compatibility with Serial ATA drives.
Product Description StarTech.com 12" LP4 to 2x Right Angle Latching SATA Power Y Cable Splitter - power adapter - 30 cm
Type Power adapter
Features Latched, right-angled connector
Length 30 cm
Connector 4 PIN internal power - male
Connector (Second End) 2 x 15 pin Serial ATA power - female
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 12in LP4...
£4.64
