StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter
£4.05
29 in stock
Delivery:
Standard: 1-3 working days
  • Length: 0.15m
  • Type: ATA
  • Stock Status: In Stock
Product codes
This 12in LP4 to SATA Power Y Cable Adapter features two Serial ATA power (female) connectors and one LP4 male connection - a reliable solution that lets you power two SATA drives using a single LP4 connection to the computer power supply. This durable LP4/SATA Y cable adapter is 1ft in length, giving you enough cable slack to position drives as needed within the computer case while saving the cost and hassle of upgrading a power supply for compatibility with Serial ATA drives.
Product Description StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter - power adapter
Type Power adapter
Connector 4 PIN internal power - male
Connector (Second End) 2 x 15 pin Serial ATA power - female
Designed For P/N: ATXPOW250PRO, ATXPOW300PRO, ATXPOW330HS, ATXPOW350DF, ATXPOW350PRO, ATXPOW400DF, ATXPOWER250, ATXPOWER300, ATXPOWER300B, S25SLOTR
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 12in LP4...
£4.05
