StarTech.com 12in Molex LP4 Power Extension Cable – M/F
£4.38
Delivery:
Standard: 1-3 working days
Key features
  • Position devices as needed within your computer case, with an extended power connection
  • Guaranteed reliability
  • Length: 30.48cm
  • Stock Status: In Stock
Product codes
Extend your LP4 power connections by up to 12 inches. The LP4POWEXT12 Extension Cable features two 4-pin Molex power connectors, one male and one female, and offers 12-inches in cable length, enabling you to extend your LP4 power connections and allowing you to position your devices (i.e. hard drive, DVD-ROM drive, add-in card, etc.) as needed within the system case.
Product Description StarTech.com 12in Molex LP4 Power Extension Cable M/F - 4 pin Molex Power Connector - 4 pin Power Extension Cable - LP4 Power Cable (LP4POWEXT12) - power extension cable - 30.48 cm
Type Power extension cable
Length 30.48 cm
Connector 4 PIN internal power - male
Connector (Second End) 4 PIN internal power - female
Designed For P/N: PYO2L, SATAPOWADAP
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 12in Mole...
£4.38
