StarTech.com 12in SATA to Molex LP4 Power Cable Adapter - F/M
£4.80
Delivery:
Key features
  • Position devices as needed within your computer case, with an extended power connection
  • Guaranteed reliability
Product codes
Power an LP4 Molex device from a SATA Power connection on your computer power supply. The LP4SATAFM12 SATA to LP4 Power Cable Adapter enables you to power 4-pin Molex devices (i.e. hard drive, DVD-ROM drive, add-in card, etc.) from a SATA power connector on your computer power supply. Offering 12 inches in cable length, the cable allows you to position your devices as needed within the system case.
Product Description StarTech.com 12in SATA to LP4 Power Cable Adapter F/M - SATA to LP4 Power Adapter - SATA Female to LP4 Male Power Cable - 12 inch (LP4SATAFM12) - power adapter - 30.48 cm
Type Power adapter
Length 30.48 cm
Connector 4 PIN internal power - female
Connector (Second End) 15 pin Serial ATA power - male
Designed For P/N: SATSASBP425
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 12in SATA...
£4.80
