StarTech.com 12in Slimline SATA to SATA with LP4 Power Cable...
StarTech.com 12in Slimline SATA to SATA with LP4 Power Cable Adapter
£7.29
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Cost-effective solution for connecting a Slimline SATA drive to a SATA equipped computer motherboard
  • Features a thin cable design, which helps reduce clutter and increase airflow within the computer/server case, for optimum system performance
  • Backed by StarTech.com lifetime warranty, ensuring a dependable connection
  • Length: 30cm
  • Type: SATA
  • Stock Status: In Stock
Product codes
Connect a slimline SATA drive to a standard SATA motherboard connector. The SLSATAF12 Slimline SATA to SATA with LP4 Power Cable (12-inch) features a SATA data receptacle and a Molex (LP4) power connection on one end, and a Slimline Serial ATA receptacle on the other - allowing you to connect a slim SATA drive to a computer motherboard that does not have a Slimline connection available.
Supporting full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives, this innovative adapter cable provides you with the connections needed to simplify the migration to Slimline SATA-equipped drives.
Product Description StarTech.com 12in Slimline SATA to SATA with LP4 Power Cable Adapter (SLSATAF12) - SATA cable - 30 cm
Type SATA cable
Interface Speed Serial ATA 150/300/600
Length 30 cm
Connectors 13 pin Slimline Serial ATA - female
Connectors (Second End) 7 pin Serial ATA - female , 4 pin internal power (12V) - male
Colour Red
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 12in Slim...
£7.29
