StarTech.com 12in TX3 Fan Power Splitter Cable
£3.97
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Length: 30cm
  • Stock Status: In Stock
Product codes
Connect two 3-pin (TX3) fans to a single power supply connector. This TX3 Fan Power Splitter Cable lets you connect two 3-pin (TX3) fans to a single power supply connector, allowing you to optimize your cooling capability without having to upgrade the power supply. Providing a flexible way to position computer case fans as needed, the TX3 Fan Power Splitter cable offers a connection length of 1ft, eliminating the need to strain the connection from the computer power supply in order to reach the fan power connection. This high quality splitter cable is constructed of high quality materials to ensure long lasting performance.
Product Description StarTech.com TX3 Fan Power Splitter Cable - Fan power splitter - 3 pin internal power (F) to 3 pin internal power (M) - 1 ft - TX3SPLIT12 - fan power splitter - 30 cm
Type Fan power splitter
Length 30 cm
Connector 3 PIN internal power - female
Connector (Second End) 2 x 3 PIN internal power - male
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 12in TX3...
£3.97
