StarTech.com 14 ft Cat 6a Blue Shielded Molded 10 Gigabit RJ4...
StarTech.com 14 ft Cat 6a Blue Shielded Molded 10 Gigabit RJ45 STP Cat6a Patch Cable
£17.58
45 in stock
Delivery:
Standard: 1-3 working days
  • Length: 4.3m
  • Colour: Blue
  • Stock Status: In Stock
Product codes
Make 10Gb Ethernet connections with PoE support. This high quality 14ft Cat 6a cable (STP) ensures dependable Ethernet connectivity, supporting 10 Gigabit performance up to 500 MHz - double that of standard Category 6 cable and five times the bandwidth offered by Cat5 - an excellent choice for Power over Ethernet (PoE) applications.
All of Cat 6a cables are constructed of high quality 25 AWG shielded copper pairs to protect against noise and EMI/RFI interference, ensuring that Cat6a cables are more than suitable for 10GBase-T Ethernet networks and Power over Ethernet applications.
StarTech.com Cat 6a patch cables provide end-to-end solutions that are tested for compliance with all TIA/ETL-568-B2.10 Category 6, UL 444 and ROHS 2002/95/EC specifications.
Product Description StarTech.com 14 ft CAT6a Ethernet Cable - 10 Gigabit Category 6a Shielded Snagless RJ45 100W PoE Patch Cord - 10GbE Blue UL/TIA Certified - patch cable - 4.3 m - blue
Type Patch cable - CAT 6a
Technology Shielded twisted pair (STP)
Wiring Scheme T568B
Shielding Material Aluminium-polyester foil
Features Molded
Length 4.3 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Blue
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 14 ft Cat...
£17.58
