StarTech.com 15 ft Coax VGA Monitor Extension Cable - HD15 M/F
£14.29
13 in stock
Delivery:
Standard: 1-3 working days
  • Type: SVGA
  • Length: 4.6m
  • Stock Status: In Stock
Product codes
Extend your VGA monitor connection without losing video signal quality. This 15ft High Resolution VGA Monitor Extension Cable is designed to provide the highest VGA video quality possible. Ideally suited for high resolution VGA applications (1024x768 and above), this high quality coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables and provides superior EMI interference protection by using ferrite cores near the connector ends.
A reliable solution for a wide range of applications, including connecting StarView KVM Switches, this high resolution VGA (SVGA) extension cable features one hddb15 male connector and one hddb15 female connector, offering a convenient way to extend a VGA or SVGA connection by up to 15ft, while maintaining superb image quality.
Product Description StarTech.com 15 ft. (4.6 m) VGA Extension Cable - HD15 VGA Extension - Triple-Coaxial - Male/Female - VGA Monitor Cable (MXT105HQ) - VGA extension cable - 4.6 m
Type VGA extension cable
Technology Triple shielded twisted pair coaxial
Features Molded, ferrite bead
Length 4.6 m
Connector HD-15 (VGA) - male
Connector (Second End) HD-15 (VGA) - female
Colour Grey
Designed For P/N: ST1212T, ST121REU, ST121RGB, ST122PRO, ST122PROEU, ST122PROGB, ST122UTPA, ST122UTPAEU, ST122UTPAGB, ST122UTPAL, ST122W, ST124PRO, ST124PROEU, ST124W, ST128PRO, STUTPRXL, USB3HDCAP
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 15 ft Coa...
£14.29
